Hi everybody, I read the FE11S thread about clicking harddrive sound. Greetings to the Greek people! I purchase a VGN-FE21S in Berlin Sony Center and the harddrive also clicks like hell. I gave it back to the service to repaire this harddrive problem. They build in a new harddrive, but it still have this clicking sound. One of the main reasons to purchase a Sony VGN-FE21S was that I could not hear any noise. Now I ask myself where is the differnce between the models they show up in Sony Style Stores and that ones they sell to the customers? They show up a noiseless rocket and gave me a machine that clicks every 5 seconds. In my opinion it should be a report for the German c't and I am sure they will find the problem.
Sincerely ... Engys
i to have a VGN-FE21S and i have not come across this noise ,and i had better not either i paid £1200 for it and if i starts making clicking noises its going back,my advice is take it back and start shouting,that normally works for me.
I had similar problem. The noise was from "parking" the heads when HDD was idle. The problem is that moments after that it goes back because of I/O activity and again and again. I got that suddenly after 2 years of using mine GRT815M.
Solution - check with some "S.M.A.R.T." tool the count of the "parks" it must increase after every click - if so - this is the problem. Get to the HDD vendor web page and get the software they are providing to configure the HDD. In my case - IBM/Hitachi Feature Tool 2.01 and read the manual. Usually it goes to a parameter they relate to performance or power save. Sliding toward performance increases the time before the HDD parks the heads. You can increase the value a little bit and it might work, otherwise increase more. Above some limit it will stop parking at all.
You can do the same from Linux with hdparm -B /dev/hda etc.
from the "hdparm" manual: -B Set Advanced Power Management feature, if the drive supports it. A low value means aggressive power management and a high value means better performance. A value of 255 will disable apm on the drive.
I feel like saying a bit more.
I have spent at least 2 days looking over Internet for solution, reading through manuals about the power save features of my particular HDD model (once I have located the problem)... anyway.
If you have at least one fan running constantly (even when on battery) and P4 not mobile! (like mine beast that I have) parking the heads every 5s and getting to whatever "intermediate" powersave mode MAKES NO DIFERENCE AT ALL - sorry for the guys that spent time implementing the feature. It is almost the opposite - parking/unparking the heads seems to consume enough power itself compared to just hanging over the plates (not safe - I know). I did what I suggested in the previous post, sliding a bit - it worked (It actually does not park since within 10s there was always I/O activity) but since I use my computer mainly as desktop replacement I decided to turn off that feature completely.
If you have clicking noise after that (I doubt that anyway) your problem is somewhere else.
Or another suggestion:
Make sure that you don't have program that accesses the disk every 10s or so. This is not an easy task if you don't have a good guess (or at least annoying). Sometimes it is beyond what you can do (Windows services or programs that keep log files...).
thanks for your answer.
did you download the sound file in the other thread? and did it sound like your problem? and did you hear of any vaio users, that could solve the problem using your suggestion?
cheess
o-o-s
Quite similar indeed…
Except that the click for me was followed by silence because the noise was coming from the parking process. In the sample, I think I can hear the parking process, way silenter than the unparking - the actual click in the sample.
Try this command line tool:
http://www.beyondlogic.org/solutions/smart/smart.htm
As administrator (in "Command Prompt" window) run smart.exe
C:>smart.exe
SMART & Simple for Windows NT/2000/XP V1.01
Copyright 2001-2003 Craig.Peacock@beyondlogic.org
Opened Drive \\.\c: . .
SMART Enabled : Yes
Model Number : IC25N080ATMR04-0
Firmware Version : MO4OAD1A
Serial Number : xxxxxxxxxxxxxxxxxxxx
Drive Size : 80.026 GB
ID Attribute Type Threshold Value Worst Raw St
[01] Raw Read Error Rate Prefailure 62 100 100 0 OK
[02] Throughput Performance Prefailure 40 106 106 5825 OK
[03] Spin Up Time Prefailure 33 125 125 1 OK
[04] Start/Stop Count Advisory 0 98 98 3409 OK
[05] Reallocated Sector Count Prefailure 5 100 100 0 OK
[07] Seek Error Rate Prefailure 67 100 100 0 OK
[08] Seek Time Performance Prefailure 40 100 100 45 OK
[09] Power On Hours Count Advisory 0 84 84 7284 OK
[0A] Spin Retry Count Prefailure 60 100 100 0 OK
[0C] Power Cycle Count Advisory 0 99 99 1997 OK
[BF] Unknown SMART Attribute Advisory 0 100 100 0 OK
[C0] Power-Off Park Count Advisory 0 100 100 3 OK
[C1] Load/Unload Cycle Count Advisory 0 90 90 106573 OK
[C2] Drive Temperature Advisory 0 157 157 1179683 OK
[C4] Re-Allocated Data Count Advisory 0 100 100 0 OK
[C5] Pending Sector Count Advisory 0 100 100 0 OK
[C6] UnCorrectable Sector Count Advisory 0 100 100 0 OK
[C7] CRC Error Count Advisory 0 200 200 0 OK
C:>smartctl -t short /dev/hda #(Linux conventions)
smartctl version 5.34 [i686-pc-linux-gnu] Copyright (C) 2002-5 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Mon Oct 9 10:23:00 2006
Use smartctl -X to abort test.
C:>smartctl.exe -l selftest /dev/hda
smartctl version 5.33 [i386-pc-mingw32] Copyright (C) 2002-4 Bruce Allen
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LB
# 1 Short offline Completed without error 00% 7269 -
# 2 Short offline Completed without error 00% 7149 -
# 3 Short offline Completed without error 00% 6189 -
# 4 Short offline Completed without error 00% 5452 -
# 5 Short offline Completed without error 00% 5347 -
# 6 Short offline Completed without error 00% 5254 -
# 7 Short offline Completed without error 00% 5192 -
# 8 Extended offline Completed without error 00% 5186 -
# 9 Short offline Completed without error 00% 5184 -
tried the s.m.a.r.t. tool from the fujitsu site. it didn't recognized any hdd in my system.
and the smart tool you provided didn't work for me. black window popped up and was closed after 0,1 sec.
Just to point out how ridiculous might be the reason for the problem.
After two years without such a problem I decided to change to login mode where the users can switch sessions. And here it is. Clicks every now and then... After a week - still the same. I rolled back in mode where only one user can login locally - didn't solve the problem. If I remember well I have traced back the problem to Windows service that was responsible for login sessions... Go figure it...
So perhaps there is a smarter solution finding out what is the real cause for it, because at the time I had this problems under Windows I did not have any under Linux on the same machine.
