Connection to TV
kruemel
Connection to TV
unfortunaltely I have not succeeded to connect my VAIO PCG-K115Z with the right Sony connection cabeling with my TV.
I heard there is also an additional other setting for the graphic card necessary, which I could not identify sofar.
Anyone can give me advice how to get rid of this ????:smileyconfused:
Thanks / cheers
kruemel
rich912
Hi kruemel and welcome,
To connect to the TV you need a 3.5mm jack to three phono (red, white and yellow), the same as an analogue camcorder cable. Like this.
To set the TV as the primary monitor; in Control Panel > Appearance and Themes > Display > Settings ¿ click the display marked 2 and select use this device as the primary monitor check box, click Apply and OK.
Go n-éirí an bóthar leat
kruemel
Hi Rich,
great, that works !!!!
thanks a million
Cheers, Kruemel:smileygrin:
rich912
You are welcome Kruemel.
Thanks for letting us know that your problem is sorted.:smileyhappy:
