CPU never runs over 5% of Maximum
matthewhambly
Spec
Vaio VGN-SZ5VWN/X
Intel Core 2 Duo T7400 2.16GHz
2Gb DDR2 SD Ram 533MHz
200Gb HD
nVidia GeForce Go 7400
Windows Vista
My Problem
The laptop is deathly slow all the time. When I look the the Vista Resource Manager it constantly says the CPU is running at 5% of its maximum and CPU usage is at 100%. No matter how intensive the program is that I run, the CPU never goes over 5% of its maximum, but using 100% of this 5% if that makes sense.
It seems like something has gone wrong with the power saving. Does anyone have any hints for fixing this?
4 REPLIES 4
kee-lo_
In Start > Control Panel > Power do you have it on full performance?
matthewhambly
Yes, it's on Full Performance right now.
This happens for any power plan.
matthewhambly
No one has any ideas? It's wierd. When I turned it on today, it was at 100% of Maximum CPU. So I loaded up my recursive PHP script to put the CPU at maximum load. As soon as the CPU went to max load, the % of maximum CPU went to 5% and everything ground to a halt.
Could this be caused by a virus? I am going to format the laptop today if I cant fix it.
kee-lo_
Are you sure your script is able to really do that? There are CPU testing programs you can use, Aida32 used to do it.
