I installed Easy CD Creator 5 Platinum on my Vaio PCG-Z1XSP running Windos XP Professional, and now my Matshita UJ-812 drive is not being recognised.
I get the following message in Device Manager:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
I don't have a TSID so I cannot get any technical support from Roxio.
Any ideas how I can reset the drivers for the DVD drive?
Uninstall Easy CD and go to www.nero.com and search for registry cleaner, this usually fixes the problem.
IT WORKS!!! :smileygrin:
This problem has given me a headache for the last 4 days. Thank you so much for your help. Next time I'll come straight here when I get stuck.
Cheers.
:smileygrin:
