every time i boot it says "insert application disk", i dont know where my disk is, and i dont want to install the vaio applications anyway. How can i stop it saying this message?
thanks for feedback.
This is annoying, but you are going to have to insert the VAIO applications disk, because otherwise this message will plague you on every boot.
You will then have to manually uninstall the junk thereafter,
really? my god, how annoying.
I dont have a clue where the disk is, can i download from the site somewhere???
Nope
If you have a HDBP you can make a new one from Start > VAIO Recovery Wizard
to solve the problem, run msconfig and uncheck the command that run this process.
msconfig works great, cheers guys
