Expansion slot?
metalace
Expansion slot?
As I was upgrading the memory on my PCG-GRT715E, I noticed another removable panel. Inside is what looks like some sort of expansion slot which is similar to the memory slots, only it's a bit smaller. It's probably a dumb question, but this is my first laptop and don't know what this is. Could someone please enlighten me? Thanks so much.
M
5 REPLIES 5
rich912
Hi metalace and welcome.
I think that this compartment is for the Wireless Lan adaptor that is standard with other models in this series.
Go n-éirí an bóthar leat
metalace
Thanks, Rich. Do you know if you can buy those wireless lan adaptors anywhere? I checked NewEgg, but they only seem to have the PC cards. Is this something you think that I'll have to get through Sony directly? Thanks again.
M
kee-lo_
Try ebuyer.com too
Ash911
I might be a bit confused, but isnt he talking about the PCMCIA slot at the side of the laptop?
Apologies if Im wrong :S
jammold
Hehe I know what your getting at there Ash, but he is talking about the expansion flap on the underside of the computer.:smileygrin:
