Just a quick question really.
Are there going to be any more firmware updates released for the Vaio-Pocket? and if there are could someone tell me when?
Chris.
For a question like this you need an oracle or some Sony engineer who is responsible for the Vaio Pocket's firmware.
Since neither of those are likely to reply here, let me tell you that a firmware update is released not periodically but only when there is an improvement or solution to a problem with the device in question.
If you have a problem with your Vaio Pocket, it makes more sense to report it here or contact the technical support than wait for a potential firmware upgrade sometime in the future.
i dont really have a massive problem. It doesnt register new music very well and always says "Registration Failed" when i disconnect it from the comp and it does the music check. Also says it when i Restore Music Info.
Also, I just like change.
