The picture which you can see here is a PCG-FR315S. But that is uninteresting.
You all know that small piece of plastic (orange arrow). That is a very fragile piece. Particuarly on the FS series. Here was a lot posts like :
"Help that thing is broken"
So, please use the thing (yellow circle) to open the lock, if you want close you laptop.
Thanks for your interest.
Oh I see
I take it sony have changed this recently?
On my 2 week old fs115b the 'slider' is in the base and the 2 hooks in the display part are very sturdy.
Wow they don't give much room for that hook to latch in the other side do they?
At the moment I'm a bit surprised, how the hooks could break.
Maybe a weakness is this part here.
I can't see that on your picture. If you put a heavy thing on your VAIO (for example a big book), could it damage the hooks.
Hi guys,
Thank you for the tips and pics.
Found them useful, the hooks seem potentially weak.
Cheers,
Mentor
No problem.
BTW, your Avatar. Is that a scene from "Ghost in the Shell"?
Seb, you're right it does look weak
I think the problem is the buffer which you can see on my picture. The FS-series doesn't have this. (correct me if I'm wrong) I think the problem is, if you close the laptop and put it maybe in a case, then the possibility that you squeeze the laptop is big.
If it not close correctly and the hook presses in the inside of the laptop, then a damaged hook would be preprogrammed.
That is definitely a design faulty.
The A series doesn't have a slider, it just has a spring-loaded button (located in the base, not the lid) to release the lid. Two metal catches do the trick quite nicely. They never misalign. After 6 months of use, no scratches or problem.
I suppose that Sony gradually learn from experience?
