TV TUNER need to be SECAM K
yomgui
Hi all,
Is someone know how to turn the tv tuner norm of my new VGC-V2S in SECAM K ???
I've no idea or information to do it...
thanks a lot dudes !
8 REPLIES 8
Akanksha
As far as I know you can set the settings to Secam L and because L is both UHF/VHF is should work but if it is exclusively K, then I don't think its compatible! :thinking:
yomgui
ok, but how I get in the setup options ??
Akanksha
Oh,
go to Giga Pocket and then click on Settings and then Select Channels, in that: Add a channel and then select broadcast location.
Hope this helps.
yomgui
Giga pocket..?
I've never seen this on my computer...?!
can you tell me more ?
Twisted-Rizla
If yours is a European model - and I suspect it is - you can only change it to SECAM L rather than SECAM K.
yomgui
yes, european... I bought it on the web, with a french site.
and how could I change it to SECAM K manually?
Twisted-Rizla
You can't. Your machine is not compatible with SECAM K.
kee-lo_
You can't, it's stuck on European SECAM.
You should really buy it in your own country, as it's more compatable with your TV system
