Hi all,
I'm steadily building up a nice music collection which is gradually filling up my C: Drive.
I want more space on my C: Drive so I can keep all my music in one place. I believe I'll have to use the Vaio Recovery tool but will this delete all my programs, files etc. Is there a way to back up so that I don't have to reinstall all my programs or am I being unrealistic
Thanks for anyone who can help.
Rich912... had a look at the C:/programfiles/Sony folder and it seems to have all the folders that are on 😧 (C: folders have more data than 😧 folders).
Might create a system restore point & then delete the 😧 folders, oh & also uninstall Counter Strike as it's way too addictive!
Do you think I should do the above?
Ta
Jay,
The folders on 😧 with Click2DVD etc are to store project files and music, they're not actually program files.
Yeah they throw a major temper tantrum!
Thanks for the warnings guys, I've decided to leave well alone.
I have noticed a problem with my 'S' keys lately, same applies to my volume control buttons. They just don't work I've checked the program setting they open when pressed and they seem fine.
Do you think this is a result of disabling UPNP on my laptop? (Apparantly having this turned on made my battery icon dissappear from my task bar so I turned it off)
Sorry to keep bothering you
Also just remembered that these problems occured after using vaio update
Could be, but I doubt it, in C:|Utils double click utils.exe
Problem sorted...
Once again a big THANK-YOU to all Club Vaio Experts!!!
No problems
Usually I reboot after installs to see if it all went well.
No problems
