Currently the processor temp is about 59 Degrees but It will certainly get more if I leave the computer on. The second fan has not even started yet. usually this happens about 30 minutes or 1 hour later.
WHAT IS THE FASTEST CPU MY LAPTOP CAN ACCEPT?
TGhanks
It depends on what your using now and if your Bios can increase the Multiplyers ect for the CPU settings.
