Hi, I have broken the yellow port by lifting the laptop up with wire plugged in.
I am guessing I need to change graphics card, is this possible? Which ones are compatible? Any idea of cost and can I do it myself? I have changed one in a pc before.
Thanks in advance
Hi al1i786,
Unfortunately it is not possible to change the graphics card as it is soldered to the Mother board..:smileysad:
Is it possible to repair the yellow port?..
I'm afraid you may need to have Sony repair your vaio for you..:smileysad:
Thanks, I guess i'll ask sony if they can repair it, thanks for the info
