Help for my VGN A317M
Mamouel
Hi to all
i am a french guy so excuse my faults in english.
I have actually on my laptop 512mb of ram. I want to have more but i dont know what kind of ram i have to choose.
Please help me.
thx a lot in advance
Sam
Thalamus.
Champion
Hi Sam
welcome to Club Vaio.. :slight_smile:
According to the specs your A317M uses DDR2 533mhz So-Dimm modules
Have a look at Cruical.com several members have bought extra RAM from crucial and another benefit from buying from Crucial is there memory compatibility guarantee. :wink:
Also you may find this guide, from Sony, on how to upgrade your Vaio's memory of interest.. :slight_smile:
Edit: I have deleted your duplicate post.. :wink:
rich912
Hi Mamouel,
You can upgrade your model to a maximum of 2 GB. Have a look at Crucial for further information.
It would also be advisable to use their system scanner to determine what modules are fitted at present as you may need to discard all of you present memory if you wish to upgrade to more than 768 MB (each of the slots may contain a 256MB module).
Go n-éirí an bóthar leat
