I've updated nvidia drivers and even the older games causes overheating
profile.country.tr_TR.title
yugimutou
hello people. i've updated my sony vaion vpcf12z1e nvidia dirver to latest from nvidia's site to play NFS: The Run but now it started to overheating even the less gpu requiring actions such as games older than 2006, desktop, even i'm in a cooled room
rich912
Hi yugimutou,
As you are using drivers that are not supported by Sony there is little we can do to help you apart to suggest that you either reinstall the original driver or try an earlier NVIDIA release.
Rich
Go n-éirí an bóthar leat
rich912
Hi yugimutou,
Rich
