Java applications not running in internet explorer
alanf52
I recently got a VGN-F21S but have never been able to view websites with java applets. Java is installed and enabled but it just won't work. I've tried uninstalling and re-installing but still won't work.
Any ideas?
7 REPLIES 7
JonnyThunder
You also need to make sure that Java is enabled in Internet Explorer advanced options.
Go to Tools -> Options
Click Advanced tab
Scroll down to find "Java (sun)" and check the box below it, which should read something similar to "Use JRE 1.6.0_03 for ".
What errors do you get, or what happens / doesn't happen when you browse a java enabled site?
rich912
Hi alanf52,
Can you try running IE7 as an administrator (right click Icon and select "Run as administrator").
If Java applets then work it is a problem with UAC, but I can offer no solution at present.
Can you confirm that Java applets work in Firefox?
Go n-éirí an bóthar leat
alanf52
Thats it, when I run it as an administrator the java applets now run. Thanks a bunch.
rich912
You're welcome alanf52 :slight_smile:
Let's hope that we can find a permanent solution in the near future as UAC is a nightmare at present. Maybe SP1 will solve some issues...
tonybeard
If all else fails and everyone including Rich's suggestion hasn't worked then you can go to internet explorer> internet options >advanced> and reset. That will definately work as I had a simular problem with java after updating the latested version and Dreamweaver wouldn't load some of my webpages.
rich912
Nice one Tony.
I think I may have found another solution to the problem.
When you update Sun Java it does not remove the old version and this causes a conflict between UAC and IE. Have a look in Add/Remove programs and delete all but the most recent update. This will hopefully resolve the issue.
Thalamus.
Champion
I'm sure I've replied to a similar problem before, can't find the thread now though..
Once Java Runtime Environment version 6 was uninstalled and then version 6.3 installed, the problem disappeared.. :slight_smile:
