Hi guys, I have Windows Vista on my FJ1S/L, and I'm looking for the original drivers of my keyboard -so I can use Fn+keys- but I'm not able.....
Someone could help me?
Thanks..
It is the ‘Vaio Event Service’ utility drivers that you need (not keyboard drivers) but if the standard Vaio XP utility drivers don’t work with Vista then I fear that you will have a long wait before Sony provide support for Vista:smileysad:
A-uhn.... and, where I could find the "vaio event service"?
Thanks rich...:smileygrin:
Have a look at this thread Wilkie – you need to install all three utilities but I have no idea whether they will work with Vista….
I suggest that you create a restore point before installing just incase all goes belly up!
Thank you for link me Rich...! I try that solution but It doesn't work...:smileycry:
Installation goes fine, but I cannot fix the problem.... I hope Sony will release beta drivers for Vista!:smileydevil:
Sorry to hear that Wilkie – I am afraid that you are probably in for a long wait:smileysad:
