Hi there vaioholics!
I need some desperate help here. I am trying to play fifa 2007 on my laptop and whenever i am trying and pressing more than button on the keyboard to try and make specific movements with the ball, my keyboard doesnot respond. However if i press the buttons individually the keyboard responds without any problems.
Can someone please tell me the remedy.
Hi, I found the same problem with my Vaio SZ3XP, when playing Fifa2007 and PES6. I only noticed when I played games...I hope there's a solution to solve this problem. Maybe it's a bios limitation, that will be solved in a future bios upgrade. If you find a way to solve your problem let me know
Yeah those keyboards are not multi key - that means once you press 2+ that's it.
You should get a USB keyboard for around 3 quid then if you bash it during a game it's no big loss.
