hello,
i have reinstalled xp sp2 with all the drivers and utilities given by sony site
(because of a lot of virus on the pc)
all is functionnal but my problem is the
when the key is not pressed, the characters given are
when the key is pressed, the characters given are
this is very weird. i dont understand
is someone has an idea?
thanks
Hi labdog,
Is you Number Lock (Num Lk) on?
If so try turning it off. If this still happens after a re-boot then there is a registry fix available at Kellys Korner that will default the Num Lk to off at boot - line 4 second column.
