Just as the topic says it dosnt shut tight, is this a common problem, hardly worth sending it back?
How long have you had it?
Faith,
Probably < 1month.
What do you mean it doesn't shut right? Are the clips closing?
Does it feel unsafe when carrying it around?
the clpis close but not tight, so it fells a bit loose.
Had it about 2 weeks.
See what the retailer can do as it's within the 28day period.
I have a A115S and have a simiar issue. When the lid is closed, I can still get quite a lot of movement.
It's not really a problem for me, but I do think it's a bit of a design flaw.
Thanks for the info guys, will have to look into this if I get an A series notebook.
Any other flaws to report?
That's a bit odd. I just took a look at three different 15" A-series, and couldn't find that behavior on those machines.
Have you tried to use glue to keep it shut tight?:smileygrin: :smileygrin:
Cheers jkeepi
glad to see I'm not the only one. Not that much of a problem, just a minor annoyance I'll have to live with, I suppose.:smileysad:
