Memory - How much faster??
Leetay
Hi all
I have a AR21M, it has, as you are aware 1GB standard.
Its running extremely fast at the moment.
I also have 'Free RAM XP Pro' programme running in the background (Tried others too, they all say similar!), I
It shows that most of the time i have only 25% RAM free, this sometimes goes down to 10% with quite a few apps. running at the same time.
Would i notice a big difference in speed/performance with another 1GB installed?
Lee
kee-lo_
Well. in theory yes, but as you're only using 250 give or take, then it's going to be the same with 2GB, except that'll be a smaller percentage.
I'd say upgrade if you want, specially if you do video work (and why not, it's so top-of-the-range it would be a crime not to induldge in HD recording) or 3D rendering.
