Missing CARDS.dll
bgs333
Missing CARDS.dll
Hi! I've just purchased this VAOI with 64-bit Windows 7. I want to use the original Solitaire, as I find the most recent version intensely irritating.  I've transferred the original .exe into the Windows system32 folder, but when I try to run it I get the message that CARDS.dll (note the upper case) is missing.  I have cards.dll in place.
The solitaire.exe file worked fine on my last machine running 32-bit Win 7.
Anyone any idea how to sort this please?
rich912
Hi bgs333,
Copying the files to the System32 folder is possibly the problem as this may cause a conflict with the built in game.
Try copying both Sol.exe and Cards.dll (from the System32 folder of the XP machine) to any other folder on the Win 7 machine and the double click Sol.exe to run or create a shortcut on your desktop.
Rich
Go n-éirí an bóthar leat
rich912
Hi bgs333,
Rich
tripodzid
Another rule of thumb: Don't go to System32 folder and do something stupid like removing or copy-paste files from and to that folder. Unless you know what you are doing, stay out of it.
________________
Business is the game!!
