Need old (pre-v1.11) firmware for UJ-841S DVD drive
anforti77
Hi. Since I updated the firmware on the OEM Matshita (or Matsushita) UJ-841S DVD+/-RW drive that came with my VGN-FE11S, I have been experiencing some annoying and persistent problems reading and burning certain discs. The current firmware is 1.11, and I would like to revert back to a previous version, but I can't find it anywhere.
Does anyone know if and where this might be available? Is there a Sony FTP archive somewhere? Any help much appreciated.
Best,
doonyakka
Thalamus.
Champion
Hi doonyakka,
Best bet is to try contacting Vaio-link for the older firmware.. :slight_smile:
anforti77
OK, will do. Thanks for the advice :slight_smile:
