New User with new S3XP which boots up with bluetooth symbol on front panel lit. By time I log inBluetooth light is off and I cannot find bluetooth in hardware list and add new hardware does not detect. Machine has proved big disappointment after faultless Toshiba
Welcome to Club Vaio sheds.
It may be that you need to turn on the Bluetooth functionality.
Right-click on the Wireless icon in the taskbar and select 'show main dialog'.
The Switch wireless devices dialog appears. Select Bluetooth¿ and click OK.
You may find this guide useful.
HTH
Ans especially make sure that your physical switch on the front side of your computer is turned on.
You should then get the switcher program that enables you to choose the following options
- wireless enabled
- bluetooth enabled
- wireless and bluetooth enabled
HTH
Thank you for the good advice. It worked fine and I now have bluetooth. I wish I could have found this in my documentation!
I am pleased that it is now working, sheds. Your on-line user manual does give scant details of Bluetooth connectivity and if you have not had a look as yet you may find other useful tips there.
User Guide.
