notebook screen
petestenny
notebook screen
Simple question what's the way to clean a notebook screen and using what?
11 REPLIES 11
kee-lo_
Yeah water can be bad for LCDs
Stephanius
Sony states this about screen cleaning:
http://www.vaio-link.com/uk/kb/3000_0/3075.html
Avoid rubbing the LCD screen as this can cause damage. Use a soft, dry cloth  and gently wipe the screen.
IMPORTANT:
Do not use any type of abrasive pad, scouring powder or solvent (such as alcohol or benzene).
Do not leave the LCD facing the sun as this can cause damage.
Do not scratch the LCD or exert pressure on it as this could cause a malfunction.
