PCG-GRT816M - Need Video Driver for Windows ME
cethai
I have a Vaio PCG-GRT816M.
For some works I need Windows ME.
I could put it on with PowerQuest Boot Magic but I have not the right Video Driver for Windows ME.
How can I do or where can I find this driver?
Thank you very, very, very much
cethai@libero.it
kee-lo_
If it's not on vaio-link.com then it's not available.
jammold
Try getting a driver from the Video Card manufacturer.
You could try to install Windows ME on a SEPERATE partition - or better still create a BOOT CD with the Windows ME files (C:\WINDOWS) on there, and these files
IO.SYS
MSDOS.SYS
COMMAND.COM
To boot off the CD, ensure you have BOOTCAT.IMG and BOOTCAT.BIN in Hard Disk Emulation Mode - it *MIGHT* just work... This DOES mean that the VGA driver will be used as default, change the SYSTEM.INI file in the WINDOWS directory of the newly made CD...
If you didn't understand a word of this then skip over it:smileygrin:
