a week ago i buy this vaio pcg-k315m from dixons. on the display, it says i should have 128 MB VRAM. but i find out i only got 64MB VRAM by using 'sony notebook setup' function. on the specifications which is come with the laptop, also shows my laptop should have 128mb VRAM.
so is anybody notic that or it just me.:smileydevil:
PS: who can tell me the right way to check the VRAM on the laptop, incase i am wrong!
Please no double posts in the same part of the forum - this will get ignored!!!
Be careful...
OK, the VRAM is userdefinable in the BIOS (tap F2 after the startup animation when you turn your laptop on) it is default set to 64MB but can be altered to either 32, 64, or 128 depending on how much of your total system memory you want to sacrifice to become VRAM!
