PCV-RX514 beep alarm
biglou
My VAIO PCV-RX514 has worked perfectly for over a year now.
Until recently, that is... Lately, when it's under load, a high pitched alarm sounds and the power button, which is blue when running and orange when on standby, flashes orange under the blue. This happens often when running Flight Simulator 2004 and Call Of Duty. I've had no problem with these games at all.
Machine is standad except for 2nd stick of 256 RAM and Belkin 54g Wireless PCI card.
7 REPLIES 7
kee-lo_
madxbri
yup i had the same problem 10 mins with the hover and the soft brush end and a clean paintbrush cleand all the dust and other nasty things out all sorted thou best you earth yourself thou
just incase you never know
there will be loads of dust ect in all your fans ect just a good clean out :smileygrin:
kee-lo_
Yeah I wish Sony would print this in the manual.
biglou
Thanks, I'll try it out....
biglou
A good muck out and a Coolermaster Silent did the trick...
Thanks all.
madxbri
no problem glad you got it sorted out
kee-lo_
:cool:
