Hi together, i have truble with my webcam, my laptop is VGN-FE41M and it works with Vista but, i installed now win XP and tried to install all the tribers on it every thing is ok just the webcam VGP-VCC4 and Bluetooth are not working. i downloaded some Drivers from Vaio download webside from other Laptops of Vaio but without chance, now please can anyone tell me how to get that cam working on win XP?...
alot of greats from Martin
Hi Martin and welcome to Club Vaio.
You need to install the driver for your VGP-VCC4 and the XP VAIO Camera Utility.
The VGP-VCC4 driver is the same one you had for Vista and will be on your Recovery Discs or can ve downloaded as part of the Original Drivers Package for your FE41M: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-FE&m=2548
The XP Version of the VAIO Camera Utility is different and you need to download it as part of the Original Utilities Package for the XP Version of your Vaio - Use the FE31H: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-FE&m=2406
