Question on Battery Life on a VAIO
NIKKS
Question on Battery Life on a VAIO.
Bought a FE41S last week.
Charged the battery and started using it for about an hour and it needed recharging again.
Just installed a game (Armed Assault, runs brilliantly by the way), so the dvd drive was used but surely it couldnt have used all this energy.
Could it be I need to flatten the battery first and then fully charge it?
The manuals for the VAIO are useless. Nice laptop though.
Thalamus.
Champion
Hi NIKKS,
The stats for your vaio state a battery life of Up to 02:50 / VAIO Optimized (Brightness Level 5, Sony arrive at that figure by under these conditions..
Running the DVD drive would reduce the battery time considerably.. :wink:
NIKKS
Thanks for the link. Blimey Im suprised Id get half an hour with those stats.
Thalamus.
Champion
You're welcome..
