When you do a recovery using the system discs or recovery partition do you have to pump in the windows serial number.
Hi there
Not as far as I am aware, as your Vaio came with the operating system pre-installed and you don't receive any 'windows' discs.
No, as the recovery DVDs uncompress an "image" of your hard drive, meaning it's just like making a Zip file.
