RAM Expansion VPCEH2N1E
TheOldHobbit
Hi, my VAIO is presently running 4gb of RAM.  I beleive this unit can be expanded to a maximum of 6gb and wondered if anyone can tell me what type of ram and how many slots??  Is it DDR3 or different and what size block do I need.  Can I do this myself or do I need to take it back to where I bought it.....  Thank you in advance.
rich912
Hi TheOldHobbit,
Your model is shipped with one 4GB module and one empty slot. It is upgradable to 8GB by adding a single 4GB module.
From the Support specifications for your model:
Memory Size (GB) 4
Memory Type PC3-10600
Memory Specification DDR3 SDRAM
Memory Speed (MHz) 1333
Memory Composition 4 GB (SO-DIMM) x1
Max. Supported Memory 8 GB
Rich
Go n-éirí an bóthar leat
9 REPLIES 9
rich912
Hi TheOldHobbit,
Memory Size (GB) 4
Rich
TheOldHobbit
Hi Rich, thank you for the information, very helpful indeed.  If I do upgrade to 8gb, am I likely to see an improved performance on my laptop.  I use it mainly for my photography, lots of graphics etc.  Thank you again.
rich912
Hi TheOldHobbit,
Assuming that you are presently using a large percentage of available RAM when processing graphics, the answer is almost certainly yes.
As memory is very inexpensive at present (a single 4GB module should cost no more than £20) it is certainly worth upgrading.
Rich
Voyager_2002
Hi Rich,
I have a similar question: I want to buy a second 4GB memory module, but since there are so many brands and options I don't know how to ensure that a memory module that I order on-line would work in my Vaio.
Relevant details:
Memory Size (GB)
4
Memory Type
PC3-10600
DDR3 SDRAM
Memory Speed (MHz)
1333
Memory Composition
4 GB (SO-DIMM) x 1
So when I am shopping for memory, do I need to check the number of pins, or what do I need to look for? Very few vendors seem to offer SDRAM, and when they do they say that it is for use in Apple machines! My model number is not included in those listed by Crucial and other vendors (it is a current EH series configured Vaio).
Hope you can help!
rich912
Hi Voyager_2002,
Your Vaio will not be listed by Crucial if it is a configured model, but if you use their System Scanner it will make recommendations for compatible upgrade.
http://www.crucial.com/uk/store/drammemory.aspx
If you are still unsure then contact them by phone or email for confirmation.
Rich
Voyager_2002
Thanks Rich,
The problem is that I have not yet bought the computer but am still working out exactly what I need and the total I will need to spend. So I cannot scan a computer that I don't yet own!
Maybe the Old Hobbit could do a scan and tell us the answer, since his RAM specifications seem to be exactly the same as mine. Or maybe you could be kind enough to tell me the key pieces of information that I need in order to search the vendors of memory modules?
And a warning to anyone else reading this thread: I visited another memory vendor's site and it did list the model number for "my" configured Vaio, but I am pretty sure that the module it recommended was wrong (it did not use SDRAM technology, but maybe that doesn't matter?).
rich912
Hi Voyager_2002,
Looking at similar models (none configured) on the Crucial site the part you will need seems to be as follows:
Part Number: CT2660105
  • Module Size: 4GB
  • Package: 204-pin SODIMM
  • Feature: DDR3 PC3-10600
  • Specs: DDR3 PC3-10600 • CL=9 •      Unbuffered • NON-ECC • DDR3-1333 • 1.5V • 512Meg x 64 •
  • Cost: £16.79 inc. VAT
Please check this with the supplier by email or phone...
Rich
Voyager_2002
Thank you: that's great.
mydearcosmo
Will it be possible to hold more than 8GB of RAM? What unit can carry such capacity?
