Replacement DVD drive for a PCG-GRT816S
HotBox
I’m looking for a replacement DVD drive for a PCG-GRT816S – the drive in it has been temperamental for most of its life.
Any ideas would be much appreciated, I’ll have a look on EBay, does anyone know if Sony may still stock replacement drives for this laptop – purchased towards the end of 2003?
Many thanks
7 REPLIES 7
Thalamus.
Champion
Hi Hotbox,
You may find a replacement drive here. :slight_smile:
HotBox
Many thanks – they got back to me: $328.00 for the DVD RW drive, seems high, but laptop drives are always overpriced, what do you think?
rich912
$328 is way over the top! Do you know the model number of the optical drive, if so try e-Bay.
Go n-éirí an bóthar leat
Josh-2552
dont buy accesories from sony! -way overpriced. i bought my laptop direct, which was fine, but for 512 ram they want £300-thats GBP, not dollars. i found the same ram for £35 :wink: so thats what i'm getting.
HotBox
I've tried EBay with no joy - any other ideas?
Josh-2552
www.amazon.co.uk
kee-lo_
They tend not to have that sort of stuff, try ebuyer.com
