I have a problem to set up my two "s buttons" on my Vaio VGN-FS115B. Even if I go to the Vaio Controller and select the right options, a message appears whith "unaivailable operation" or something like that (when clicking on the "s button menu").
Please help me to set them up.
Thanks.
Are you logged in with Administrator Rights? If you and it still doesn¿t work you may need to run Utils.exe package but I am not sure on this ¿ perhaps someone else will confirm.
Yep correct Rich.
Login as an Administrator then run C:\UTILS\UTILS.EXE.
If it is missing from your computer, then please download a new copy from VAIO-Link
Thanks for the confirmation James.
thank you guys
