Hello,
Is it normal for the fan on the S3XP to be coming on pretty much constantly but only in short bursts? The application that I'm using is pretty CPU and memory intensive (Netbeans with quite a few projects open at the same time). It would be less annoying if it was just on all the time!
Apart from the fan I'm very pleased wth it :smileygrin:
Yes, it seems to be normal.
Especially with CPU intensive applications:smileysad:
It's a very noisy laptop apparently.
