Screen problem with PCG-GRT915M
daveyryan
Hi.
Someone bought me a Vaio PCG-GRT915M some time back. All's been well until recently, when it started playing up when I turned it on.
What happens is that when I switch it on, all I get is a grey screen with black lines across it horizontally. Usually, after a lot of turning off and turning back on again, it will eventually boot as normal. I reinstalled it completly (with XP Home), reset the BIOS defaults, tried it plugged into the mains and running on battery, but no joy. I fear it's something nasty like a problem with the screen or the graphics card, but wondered if anyone else had any ideas that would avoid a possible costly repair bill ...
Thanks!
11 REPLIES 11
daveyryan
Try these people, they should be able to give you a quote by phone or email.
Many thanks Rich.
rich912
No problem Davey, best of luck!
Go n-éirí an bóthar leat
