slow start up
newarre
slow start up
Hi - This is driving me mad - I have a VGC- RA204 which up until a few days ago worked fine. However on inital start up the thing seems to hang for a long time. Once at log on point you can log on o.k. I have re-installed windows which seemed to cure the problem. However as I loaded back the various software and re-booted the problem returned. I have now re-installed windows several times, same problem, except now it hangs straight from a fresh re-install Seems to have got worse). It does eventually start up and I can log on. Once logged on it appears to work O.K, except for this really annoying long delay in inital starting up. My suspicion is a hard drive fault - anyone any idea's ?
:cry:
7 REPLIES 7
kee-lo_
If you press alt+ctrl+del which process is using up the CPU? I am wondering if it's VAIO Entertainment Platform?
newarre
I have just switched on my PC to check the CPU usage. Now I had turned my mouse & keyboard off (to save batteries). When I switched my PC back on I forgot to switch the mouse & keyboard back on, but - hey presto it fired up as it should at the correct speed. I have tried this several times and still works.
A had connected a cable mouse & keyboard just before the problem arose - I am now wondering if this could be the problem. Anyway the processes being used are:
wuauclt.exe
taskmgr.exe
SNDrvc.exe
Launcher.exe
VzTrayIcon.exe
SSMSFillter.exe
acrotray.exe
pdservice.exe
AvRmCtr.exe
ALCWZRD.EXE
atiptaxx.exe
UsrPrmpt.exe
ccApp.exe
VAIOUpdt.exe
SOUNDMAN.EXE
SymWSC.exe
VzTaskscheduler
VzFw.exe
navapsvc.exe
explorer.exe
ccProxy.exe
spools.exe
ccEvMgr.exe
ccSetMgr.exe
sychost.exe
Isass.exe
services.exe
winlogon.exe
csrss.exe
smss.exe
VzRs.exe
alg.exe
VzHardwareReso
System
System Ideal Process
kee-lo_
Wonder why that's happening?
profile.country.de_DE.title
seb21__
wuauclt.exe
taskmgr.exe
SNDrvc.exe
Launcher.exe
VzTrayIcon.exe
SSMSFillter.exe
acrotray.exe
pdservice.exe
AvRmCtr.exe
ALCWZRD.EXE
atiptaxx.exe
UsrPrmpt.exe
ccApp.exe
VAIOUpdt.exe
SOUNDMAN.EXE
SymWSC.exe
VzTaskscheduler
VzFw.exe
navapsvc.exe
explorer.exe
ccProxy.exe
spools.exe
ccEvMgr.exe
ccSetMgr.exe
sychost.exe
Isass.exe
services.exe
winlogon.exe
csrss.exe
smss.exe
VzRs.exe
alg.exe
VzHardwareReso
System
http://www.google.com/
http://www.altavista.com/
http://www.abacho.com/
http://www.fireball.de/
http://www.excite.com/
http://www.dino-online.de/
and endless more
The web is a wide open book.
You just need to type a frase into any search-mashine and it will answer you.
click me to see an example
The are more than just Google or Yahoo.
You can find them all with Google for example.
I don't want that you feel angry now. I just want to say that it can be very easy to answer alot questions buy yourself.:smileyhappy:
anyway, this here is one reason for a slow start up
Go into C:\Windows\
There you will the folder prefetch.
Mark every file in folder "prefetch" and delete them.
Windows safes softeware entries there. Every Software which has an entrie in this folder will be load into the RAM at the system startup.
This will slowdown your VAIO some day. That's why it could be a good idea to delete the files every month or so.
I hope this helps.
kee-lo_
Yeah prefetch is a pain in the butt
I see you have Norton installed.
Have you tried disabling it to see if it is causing the problem?
It does funny things sometimes on Startup and Shutdown.
kee-lo_
Yeah it used to delay my bootup
