Laptop: VGN-A517B
Hi All,
Just got a couple questions I would appreciate your responses to ...
1) Vista support. Any news? Must of it worked fine but cannot get Bluetooth running (XP drivers do not work). Also Sony's utilities (adjust brightness, volume buttons etc) do not work.
2) Touch Pad. Is there any way to disable the touchpad when an external (USB) mouse if connected?
3) Is it possible to upgrade the graphics card?
4) Is it possible to upgrade the hard disk?
Thanks in advance.
VTL
1) No news, but on the Microsoft site they have some software which can analyse the system for readyness.
2) Yes, in Sony Notebook Control
3) Nope
4) Yes, any 2.5" hard disk will work. Hitatchi Travelstar drives are good and not power hungry
