sony pcg-7151m driver
gkilic
Is anyone knows where can I find sony pcg-7151m driver for Win7-32bit
Thank you,
rich912
Hi gkilic,
You are quoting the chassis number from the underside of the notebook which can be shared by several models and will need the product model reference in order to find drivers – have a look on the screen surround and you may find something similar to VGN-NSxxx
Given the correct product reference we will be able to point you in the right direction.
Rich
Go n-éirí an bóthar leat
Hola quisiera saber donde puedo descargar los drivers del modelo Sony Vaio PCG-7151M
rich912
Hi Silva_Flow,
As I posted previously, you will need to find the correct product name. It will start VGN-NSxxxx – have a look on the screen surround or in Vaio Control Center. Once you provide the correct reference we can point you in the direction of drivers.
Rich
