Hi - I got my laptop at the end of June and have been very happy with it.
At the weekend I opened the laptop and to my horror I found that the screen showed what looked some sort of crack! On feeling the screen it is in fact intact, and the outside casing is not marked either. Please see attached picture.
This morning (Sun 7 Oct) I opened the laptop again and the fault seems to be creeping across the screen; whereas previously it was between 1-2 cm, not it is at least 4-5cm wide and is basically unuseable.
I really can't think how this could have happened as I am really careful with it and have even bought a case for it.
Can someone please have a look at the pictures and tell me what they think the issue might be. I really needs this fixed for a presentation I'm doing at the end of October.
I am hoping it can be done under warrenty.
not sure whether thse pics are coming through...
Hi Sony-Dutchman,
Sadly we can't see your pictures..:smileysad:
have a look at this thread on how to post images..:smileyhappy:
Hi Sony-Dutchman,
Unfortunately the pics are not displaying. You need to upload these to a host such as Photobucket and then provide an image link from the host…
Thx guys. Here are the images (hopefully )
OMG you have my sympathy, your screen is cracked and will need replacing. It could be difficult to persuade Sony that this is a manufacturing fault but I would give it a go. You may also be able to claim from your house contents insurance if you are lucky.
I agree with Rob , if you are unseccessful with the warranty claim and you wish to replace the screen yourself have a look at Nexttronics..
Bad luck
An allied question - is the hinge plastic on your SZ2 scored with tiny scratch marks - I mean just along from the LEDs and above the speakers, to the right and above the on switch. Mine is, mysteriously and I wondered about yours from the pics
Ugh that's terrible!
Hope Sony can help you out with this one, as that's really screwed up.
Did you move it at all?
Obviously the "cover" of the screen is made of a polymer and so is unlikely to be damaged, say if you poked the screen and it cracked (I'm not saying you did this just example) the cover would probably look untouched where as the diode screen could crack, and probably the heat from the screen (contracting and expanding, cooling and heating up) could then cause the crack to spread as it has. Therefore this could bend two ways (I mean the situation) you can call sony and they will claim that you have in some way caused the screen to crack and so it will not be covered by warranty, or you could try and argue, my only thought on how this could have happened would be that if there was a slight manufacturing fault, where there was an imperfection in the manufacturing of the screen where there was a tiny crack/tear at the top or bottom (wherever the crack eminated from) and over time the process of heating up and cooling down has caused the crack to expand/creep, this obviously would speed up over time, so once the crack had got underway it would have quickly spread over the screen as it has done. By the look of it, with it being an LCD, so liquid crystal the liquid has spread, if there was a stress fracture you would expect a cirular crack pattern, as a stone smashing a windscreen for example, not a linear line, where as if you say dropped the laptop (again I'm not saying it has been dropped) it may have produced a crack at the edge with it then spreading.
I hope you can get this repaired under the warranty, please update us on your progress,
Andy
