Hello,
I have reinstalled Windows XP on my TR2MP and despite loading ALL drivers the Network Capture software does not start - it is unable to initialize the camera! When the system is restored from Recovery CD all works fine so this is not a hardware failure. Any suggestions what could be the problem? What drivers should I check for to be sure that the camera is installed correctly? (I can not use the system as installed from Recovery CD so I do need to go through the manual installation)!
Thanx,
Kris
Turn off USB power saving on the camera.
