Transfer files and settings wizard problem
kagyu
Wanting to transfer files and settings from old Vaio PCG-9B3m to new VGN-FE31Z and using the wizard on the new one, it lists only the memory stick (E) drive as an option to transfer the setup to the old machine which has no memory stick drive. Neither machine has a Windows XP cd. How can I proceed?
8 REPLIES 8
Thalamus.
Champion
Hi kagyu
Welcome to Club Vaio, :slight_smile:
You may find this link of interest..
kagyu
Thanks for that and the welcome! In have treid connecting with a network via ethernet and a router but tho a third PC can see and share with the new and old laptops they dont seem to be able to see each other. Then I tried adirect crossover ethernet cable but still have the same problem.
Why doesn't the new Vaio give an alternative to drive E?! It looks so simple till you get down to the nitty-gritty!
kee-lo_
The only other thing I can think of is using a large USB stick (around 2GB to be on the safe side, you can get them for around £20 now)
kagyu
Brilliantly simple solution, thanks
kee-lo_
No problem
profile.country.de_DE.title
seb21__
I think the best way is a i-Link cable, If you a lot files to transfer.
I've bought on myself and it saved a hell of time.
If you haven't Gigabit Lan onboard go for iLink (Firewire).
kagyu
Sorry for jumping threads on this topic, but the problems did break down into connection/network ones and actual wizard ones!
Having now found solutions and successfully transferred what was needed, thanks to everyone's help on this forum and sheer time and effort, I'd like to record "how" for others.
First, the connection. I used an ordinary metre length of ethernet cable with a crossover adaptor from Maplins. Thanks for the Firewire cable suggestion from Seb21 which I didn't think of, it might be a bit quicker but I found the ethernet cable perfectly fast enough.
A critical factor I found in connecting the two PCs is that ALL firewalls have to be deactivated. I turned off both Windows firewalls but then discovered there was further one incorporated in my anti-virus software.
Connection without firewalls is best done safely by direct connection ie with internet disconnected.
To create a network you have to have both Users logged in with passwords as administrators, no password, no network creation!
Here is Blencogo’s (from this forum) excellent guide :-
I assume you have two IP addresses like 192.168.0.1 and 192.168.0.2
1. First get identical accounts/passwords on both the XP Pro and XP Home PCs, such as 'Admin' with a password of 'Admin'.
2. Turn off simple file sharing. Explorer -> Tools -> Folder Options -> View. Scroll to the bottom and untick simple file sharing.
3. Ensure both machines are in the same workgroup, this is found by right-clicking My Computer on the desktop and choosing Properties then choose Computer Name then click change, by default XP Pro and XP Home use different workgroup names (Workgroup and MSHOME) for some obscure reason.
4. Share the folders you want access to by opening Explorer and right-click the folder or drive and choose sharing, follow the tabs.
5. Turn off all firewalls.
5. Reboot the PC's (XP Pro first) and pray!!
I had done all that but still had no connection. Then checked on each computer as follows:-
Network Connections – Local Area Connections – right click –Status – Support
- To read the IP address currently assigned to that computer.
Do this on both machines. Then go to Start – Run
-Type in Ping {IP address} (of the other computer)
If it’s working you can see it gets a reply.
In my case I was getting communication only one way – it was then that I discovered the extra software firewall still active on the new Vaio. Once deactivated, it was miraculous to see that little icon pop up in the workgroup computers folder!
After finally managing to connect, everything was quite straightforward, apart from minor problems with making folders shareable. (Per folder :– Tools- Sharing)
The files and transfer wizard works fine after I followed Kee-Lo’s suggestion to use a USB stick. However having established the direct connection I used that exclusively for the files transfer.
It’s simple when you know how –thanks everyone!
kee-lo_
The firewalls shouldn't have stopped you using drive D though
