Upgrade memory for vaio vpcz217FC
adiphia
Just one question, I would like to upgrade my memory  to 8 GB, 4 GB is kinda low for me. My laptop memory runs at 1333 MHZ, just wondering is there a particular module for vpcz217fc or any memory runs at 1333MHZ will do . Thanks for you help.
adiphia
The memory is soldered on the motherboard.so never mind, you can't upgrade it.
adiphia
Hi adiphia,
Unfortunately you are right.  The VPCZ2 models do support 8GB but this must be preinstalled at the factory and cannot be upgraded later.
:slight_frown:
