UPGRADE RAM by FS-415E
rzepinski
Hi, I have one question, which Ram should I take for my FS-415E. Id dont know it, because in the specs there ist Ram with 533Mhz and PC2-3200 Ram ist always with only 400 mHZ, what does should I Take?
Thalamus.
Champion
Hi rzepinski,
Welcome to the Forum, :slight_smile:
Have a look at Crucial.com they list 200-pin SODIMM DDR2 PC2-4200 for the FS 415 range.
If you select scan my system crucial will recommend compatible upgrades for your specific system.
Kris1990
crucial is the best for RAM upgrades
