Vaio Battery
zoowalk
Vaio Battery
I own a Vaio VGN-S5M which uses the battery VGP-BPS2 (11.1 V/4800 mAh).
Is it possible to use the battery type VGP-BPS2A (11.1V/4400 mAh) as a spare one for my laptop without damaging it? Regarding the size, it would fit perfectly.
Many thanks. I am looking forward to hearing from you soon.
Thalamus.
Champion
Hi zoowalk,
Welcome to Club Vaio, :slight_smile:
It states on this site that the battery is compatible with your VGN S5M, however it's your choice if you use it.. :wink:
