Vaio Gate
profile.country.en_IE.title
ridunne99
Vaio Gate
I bought a Sony Vaio and just really getting to know it.  The Vaio Gate, the dropdown list of icons, it has 2 Skype and 2 BBC iPlayer Desktop icons.  Any idea why or how to remove the duplicate icons?
rich912
Hi ridunne99,
Place the cursor over the duplicate icon, hold down the left mouse button and drag the icon out of the dock to the desktop. The icon will be removed but not placed on the desktop.
This link may help if you have further questions on Vaio Gate.
http://www.sony.lt/discussions/message/661878
Rich
Go n-éirí an bóthar leat
rich912
Hi ridunne99,
Rich
profile.country.fr_CH.title
cautige
Would you also know how to personalise the icons on Vaiogate?  Every new application I pin there comes up with the Google chrome icon (even though the text states what the application is), I would like to identify them more easily.
Thanks for any assistance
C
rich912
Hi cautige,
I don’t have Vaio Gate on any of my Vaio’s, but I would imagine that customisation is the same as for any desktop icon...
Right click the icon and select Properties. On the Shortcut tab click ‘Change Icon...’ > Click Browse and navigate to the folder that contains the executable for the program (usually in C:\Program Files). Select and Apply.
Rich
