trying to do a system recovery on vgc-m1
when i try to open the 'vaio recovery utility' i get the message:
"This program runs on Sony VAIO computers only.
This computer is not recognised as a Sony VAIO computer."
anybody any ideas?
thanks
dabberwatcher
Does this happen when you press F10 at bootup?
Hi Dabberwatcher,
Here is Sony's solution to the problem: This Wizard can only be executed on Vaio PC's, This computer is not recognised as a Vaio PC
hi kee-lo, thalamus
thanks for the help, but no joy
its goin back to supplier and let them sort it
thanks again
dabberwatcher
I hope you haven't sent your PC back to the suppliers yet, I had the self same problem with my V2S and after weeks of not risking installign or updating it I eventually found out what to do. On the C: drive there is a folder called utils. In this folder there is an application called utils, I simply ran this and my Sony recognition problem was resolved. I had previously emailed e-support and after a few exchanged emails the only answer they could come up with was a faulty BIOS chip that would need replacing at the cost of around £400 and as I'd not taken out an extended warranty..opps.
