Hi where and how can I get a recovery DVD for a VAIO AR 21 S Notebook ?
I need to restore the system. Windows Key is available, we need only the restore image. (was deleted by mistake)
Thank you!
Andrei
Hi andreix,
Just to be sure that you have deleted the recovery partition, try pressing F10 repeatedly when starting your vaio as this may still start the recovery process..
If however this does not work you can purchase a set of recovery disc's from Vaio link..
