After XP SP2 setup, VAIO Zone put this error on screen and stop.
(ID erreur = 0 - 0 - 15465 - 1737).
Is there somebody with knowledge about this ?
Get the latest updates from VAIO-Link
Thanks for your answer.
Unfortunaly, I download and setup all updates from vaio-link without any success.
Could you tell me why, after my registration in the VAIO Club, I could not reach the e-support ?
I receive always the same message: "Your email address could not be found in our database.". But I don't find any way to tell them that my email is correct and accepted (with answer) by the VAIO Club!
eSupport is messed up, you need to call Sony to enable you to use it.
Hi Kee-Lo,
Week-end is not a good time to have trouble with Sony...
Let me explain my problem completely:
I want to use XP professional instead of the Home version pre-loaded on my new VAIO RS704 and I have a valid XP Pro license and the original XP SP1 CD.
The pre-loaded XP Home version is SP2 and I can't upgrade from my CD because it is a XP Pro SP1!
I try a few thing:
-Setup XP Pro on the C partition in the same folder than XP Home. After that, I setup all drivers and VAIO software found on the SONY reinstall CD #2 . Everything was fine except the error when launching VAI Zone application!
-Complete reinstall with CD #1 and #2. Every thing was ok. VAIO Zone also. I restart the PC with the XP Pro CD inside, and try the "R" option in order to "repair" the previous install on the C drive. It ask me for the Administrator password (I have to set in the safe mode before a password to the administrator account), and stop after entering the valid password.
-Setup XP Pro with formating the first partition, all drivers. But here, the SONY reinstall CD #2 did not want to setup VAIO Software.
So, do you think possible to upgrade to XP Pro without losing VAIO software and VAIO specific functionnalities ?
Thank in advance.
Yeah weekends are bad with VL
This is quite a tricky procedure, and it doesn't work if you need VAIO Zone.
The way Sony have done it means you have to sacrifice their software!
