Hi can anyone suggest how I may connect my VGC 2S to my near by television using a cable.I can't find an output on the unit ?
No video or s-video?
maybe it's a mini-jack like this one
You should take a look at your VAIO-manual.
The 'all-in-one' Vaios of the V-Series and the LA-Series do not have any form of Video output. All connections are 'IN' only.
The only possibility would be to buy a USB external analogue capture card that also outputs AV. The quality won't be great.
ewww, I didn't know that.
