VGC-V2M and Wi-Fi
PapaB
VGC-V2M and Wi-Fi
I have a VGC-V2M and a four year old Toshiba Satellite S-1800 laptop. I also have a 2mb. AOL Broadband Connection. All I want to do is share my Broadband and files with my laptop.
Am very confused as to what I need to purchase. Would a simple router, plus a PCMIA card Wi-Fi adapter (for the Toshiba) suffice ?? Any help would be appreciated.
5 REPLIES 5
kee-lo_
Hi PapaB
You're right there, you'd have to have the V2M wired to the router (unless you want to go wireless then you'll need another PCMCIA card
I recomend this router and this card
PapaB
Hi. Many thanks for your help. I have checked out the router, but it states that I require an external cable or DSL modem with an Ethernet interface. I currently have a B.T. Voyager 100 and don't think this complies. Does this mean I will have to puchase a new modem as well ?? Sorry to appear so ignorant !!
profile.country.de_DE.title
seb21__
Hi PapaB,
The B.T. Voyager 100 is a ADSL Modem. If you want share the internet connection then you would need a ADSL Router, like Kee-Lo said.
You could share this connection with the modem also. But you must connect Computer A with the Computer B which is connect with the Modem. Then you must configure a internet connection via network on Computer A. Because Computer B has the internet connection.
But you can use the interernt with Computer A only if the Compute B is ON.
HTH
mvanwambeke
The best way is probably to purchase a router via your internet provider. Most of the time, they have nice pre-assembled packages for small networking.
( this gives you the advantage that you have support for setting this up by your ISP)
The V2M has a wireless card so you could purchase a wireless router (of course you'll have to check if you other computer has one as well)
This would save you the hassle of dragging round with cables.
kee-lo_
PapaB
Scrap that - this one is a good router which has a firewall too, and you don't need the BT Voyager anymore.
As for cards, well Belkin are always good as they offer a lifetime warranty I use this one excellent value for money
eBuyer has some great bundles too
